Battery recommendation
50,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DAVIDCC
Sir, when I buy a battery, what are good brands? Interstate and Delco have good recommending, the Champion I have now really works. Any other good battery makes? Thank you. David
Jun 20, 2020 at 7:03 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, both Interstate and Delco are both great brands.Odyssey is one of the best out there in my personal opinion. Just be sure when buying a battery for your vehicle you buy one with the correct CCA -cold cranking amps. The formula is to double your cars cubic inches and that will be the correct CCA's Your 1.6L equates to about 98 cubic inches.You will therefore be looking for a battery with a minimum of 200 CCA's. Hope this helps and thanks for using 2CarPros.
Jun 20, 2020 at 7:40 AM
