Battery replacement, do I need to disconnect the negative cable first?
57,000 MILES • 1.6L • 2WD • MANUAL
NOCKSTER74
I need to change the battery. 100% of people say to disconnect negative terminal 1st, but this is impossible on Peugeot partner.
Aug 14, 2023 at 6:11 AM
  • 55,554 POSTS
You can disconnect the positive side first but please make sure you don't touch anything with the tool against ground because you will have a direct short. Please let us know if you need anything else to get the problem fixed.
Aug 15, 2023 at 3:07 AM
BRENDON S
  • 653 POSTS
Hello NOCKSTER74,
This video should help as well. From what I can find your vehicle is designed to have the positive removed first. Then Install in reverse order. Looks like there are a couple of modules that will need to be moved to give you room to slide out the battery.
Here is the link to the video:
https://youtu.be/LENQdFY0DnI
Thank you,
Brendon
Aug 15, 2023 at 3:19 AM
NOCKSTER74
Yeah, I had previously watched video, it just unnerved me that everyone was taking neg terminal off 1st, but everything went okay. thanks for your help.
Aug 15, 2023 at 3:50 AM
BRENDON S
  • 653 POSTS
Hello NOCKSTER74,
Awesome happy to hear it and I can understand, the last thing anyone wants is another issue.
But happy to help! Thank you for contacting us!
If you need anything else let us know or start a new question.
Have a great rest of your week!
Thank you,
Brendon
Aug 15, 2023 at 5:12 AM
