New Battery already dead
150,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
LAURAFRAME
My battery is dead and my interior lights have not worked since I have owned this vehicle. I drove it yesterday and when i went to leave this evening and the battery was dead. no dash lights and no sounds of it trying to start. I am not getting anything out of it. I have gone over everything. Battery was just replaced and the alternator has been replaced. I am lost with this.
Nov 30, 2016 at 10:28 AM
JOHNNY G.JR
  • 320 POSTS
First check battery for voltage with a DVM ,next check battery and cable connections for tightness and cleanliness. Recharge battery if reading is twelve volts or less after charging battery. check voltage down at starter battery post, if less than reading at battery it is a possible cable issue or internal corrosion.
Nov 30, 2016 at 10:37 AM
JOHNNY G.JR
  • 320 POSTS
First check battery for voltage with a dvm,next check battery and cable connections for tightness and cleanliness, Recharge battery if reading is 12 volts or less,after charging battery ,check voltage down at starter battery post,if less than reading at battery,possible cable issue,internal corrosion
CJ MEDEVAC
  • 11,000 POSTS
Do/ Try some of this stuff in my link! Before you spend money!
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
If these easy things do not solve the problem, and your battery tests fine (not seems fine).
Symptoms seem to show either the battery or the alternator (not charging the battery) may be the problem.
Both can be tested at most auto parts stores usually for free!
If you can jump it/ charge the battery and get it to the parts store, both can be tested "on" the vehicle.
Should you need to purchase either, Before you compulsive buy, lLook at my link again towards the end of the thread is another link. The methods within it may save you some money at the store I use a lot, or even at others (using their own methods).
Return with good news!
The Medic
Nov 30, 2016 at 10:42 AM
