Battery
75,000 MILES
GR8SCOTT154
Just a simple question. How do i get the battery out of the car. It is dead and needs replacing.
May 10, 2013 at 2:49 AM
JDL
  • 16,098 POSTS
My info says.
Remove negative battery cable then positive battery cable.
Remove plastic battery cover.
Remove battery hold-down retaining bolt and hold down bracket.
Remove battery from vehicle.
If the battery is a close fit, if you have battery top posts. There is a strap that fits over the top posts, allows you to lift the battery. Your local autostore should have one.
May 10, 2013 at 4:33 AM
