Battery draining
123,000 MILES • 2.7L • 4 CYL
HWSHIRA
Battery is about two months old. Car was dead today. Voltage was 0.2 volts Makes me wonder if the battery is totally disconnected. Jumped it from another car for fifteen minutes. Charging voltage was 14 volts. Car then started a-okay Disconnected jumpers and voltage was 12.5 volts. I can't believe the battery charge went from 0.2 to 12.5 in fifteen minutes. Can you? Is there a low voltage cutoff that disconnects the battery if it drops below some safe level?
Jan 16, 2019 at 5:21 AM
Good evening,
No, there is not. It sounds like you have a parasitic drain to make the battery go dead. I would check to be sure.
https://www.2carpros.com/articles/car-battery-dead-overnight
Jan 16, 2019 at 8:06 AM
CJ MEDEVAC
  • 11,000 POSTS
So the voltage on the Stratus was 12.5 volts while it was running?
If so, did it get better the longer it ran?
Normally, you will see running voltage being in the 14 volt range.
Sometimes batteries can act funny, they might require more thorough testing. If the running 12.5 volts never improved (if that was the situation) alternator may not be operating as it should, or it's path to charge the battery could be open.
Check this out,
This came from our "Repair Guides" at the top right of our pages.
I'm giving you that link too so you don't have to go looking. Check out the "electrical" section, there are several articles dealing with the battery also.
Let us know what your findings are.
The Medic
Jan 16, 2019 at 8:36 AM
HWSHIRA
Thanks for the prompt reply and the suggestions. I checked the voltage again today with the car running. It was 14.0 volts right where it should be. It was 12.4 before I started the car.
My best guess is that the trunk lid was not quite locked down overnight and the light drained the battery. But I still find it hard to believe that it actually took the battery down to 0.2 volts and that it charged up to 12.5 within fifteen minutes! I suspicious of an intermittent regulator and will check it periodically over the next few days to see what happens.
Jan 17, 2019 at 6:53 AM
Did you do the parasitic draw test I suggested?
Jan 17, 2019 at 7:08 AM
