Car will not start after having transmission and driveshaft replaced
186,000 MILES • AUTOMATIC
NEKA254
I just drove my car home from the shop from getting the transmission and driveshaft replace. I get home and now it will not start but my lights and everything works. What would that be? Please
Aug 30, 2018 at 11:05 AM
  • 110,248 POSTS
Since the vehicle was just apart, it sounds like they may have left a battery terminal loose, forgot to tighten the ground wire to the engine, or left the wire on the starter loose.
Have you contacted them with this issue? I feel they should be responsible if it is anything related to what they did or worked on.
Aug 30, 2018 at 11:56 AM
