Battery ground connection location needed
150,000 MILES • 1.8L • V6 • 2WD • MANUAL
WISE.NICHOLE
Where does the battery ground wire connect?
Jul 10, 2020 at 8:29 AM
I attached the process to remove the cable. There is a ground stud under the battery on the front support. Take a look at the pictures and instructions and let us know if you have more questions. Thanks
Jul 10, 2020 at 9:07 AM
