something keeps draining the battery?
275,000 MILES • 2.9L • 4 CYL • 2WD • AUTOMATIC
KLEGGSKAA1
  • 22 POSTS
I hit a deer on passenger side i fixed all of that now something keeps draining the battery.
Oct 23, 2023 at 8:48 AM
  • 55,721 POSTS
It is common for the A/C clutch relay to stick on and drain the battery, I would remove the relay to see if the drain stops. Please check out this guide as well:
Also, please check out this guide and I have included the location of the relay. Check out the images (below). Please let us know how it goes.
Oct 23, 2023 at 9:00 AM
KLEGGSKAA1
  • 22 POSTS
We checked relay it is fine, what else can we try?
Oct 23, 2023 at 11:58 PM
  • 55,721 POSTS
I would load test the battery, the jolt could have caused it to go bad. here is a guide to help you do so:
Please go over this guide and get back to us.
Oct 24, 2023 at 1:23 AM
