Battery
145,000 MILES • 2WD • MANUAL
TJELLI
The negative terminal has a box on it, is this needed or can it be by passed?
Dec 4, 2018 at 11:27 AM
  • 110,248 POSTS
If the negative cable "box" has a few black wires coming from it, you need to use the same thing. Those wires are grounds for specific components which require the best ground possible and are protected via fusible links.
Let me know if that is what you are looking at. Also, if it is not, can you upload a picture of what you have so I can get a better idea?
Dec 4, 2018 at 1:04 PM
