Battery draining
130,000 MILES
KATACCTS
Hi, for some reason my battery has been dying out and didn't charge. it has happened a couple times. I changed the ground on the battery because it was breaking it lasted about a month. then when I went to go somewhere it wouldn't start, but the night before it started with no problem. not sure what's wrong.
Jan 5, 2020 at 10:22 AM
  • 110,248 POSTS
First, make sure the battery terminals are clean and tight. If you haven't already, you should try load testing the battery. It's best to do it with a machine, but here is a link that explains how to do it at home:
If the terminals are tight and clean and the battery is good, we need to check the alternator's output to the battery. It isn't hard to do. Here is a link that explains how to do it. You will need a volt meter or multi meter.
Here are a couple links you may find helpful:
Do this and let me know the results so I can guide you.
Jan 5, 2020 at 12:58 PM
