Base idle screw
300,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
WISH30
  • 124 POSTS
Does someone know is there any screw for manual base idle adjustment on this type of throttle body? Thanks in advance (988F-FE)
Sep 18, 2021 at 2:01 PM
  • 110,246 POSTS
There isn't a base idle adjustment. Idle speed is controlled by the powertrain control module (PCM) via the idle air control valve (IAC).
What is the vehicle doing, idling too high or low? Also, have you tried to service the IAC? Here is a link that shows in general how it's done:
https://www.2carpros.com/articles/idle-air-control-valve-service
Sep 18, 2021 at 2:36 PM
WISH30
  • 124 POSTS
I have tried to replace IAC valve but with cheap one from Aliexpress. It is the same problem, sometimes stable idle sometimes unstable idle. I suspect maybe it is wiring harness that comes from PCM but it would be too difficult to mount new wires directly from there. Also can I measure somehow the signal stability, I mean if I unplug the valve and put some voltmeter or frequency meter or amperage meter? I tried to unplug the IAC on hot vehicle and it idles perfectly, completely perfectly. I decided to drive without IAC, but when started on cold vehicle, it immediately turns off if the gas pedal is not pressed because IAC is closed by default.
Sep 18, 2021 at 2:45 PM
  • 110,246 POSTS
If you are checking the wiring, the easiest thing to do is move the wires around to see if the voltage jumps around.
Are you sure the IAC you got is good? I have seen so many faulty, inexpensive parts lately. The idea that it ran well when it was warmed up leads me to believe it's the sensor. Also, did you notice if there was any carbon or dirt where the IAC mounts?
Sep 19, 2021 at 10:55 AM
WISH30
  • 124 POSTS
It runs okay when warmed up (but IAC unplugged from harness). What sensor do you mean? There was not any dirt everything was clear.
Sep 21, 2021 at 8:53 AM
  • 110,246 POSTS
I was referring to the IAC sensor/motor.
If you look at the attachments below, they are three different sets of diagnostics specific to the IAC. Each one is based on different possible issues.
Take a look through this and let me know if anything helps.
Also, if you have a scan tool that can provide live data information, let me know what the coolant temp sensor is signaling and what the short term fuel trims are.
Sep 21, 2021 at 9:16 AM
WISH30
  • 124 POSTS
Just one more question please, because purge valve is a new thing for me, where is it located? Thanks in advance.
Sep 21, 2021 at 8:41 PM
  • 110,246 POSTS
No problem. It's under the hood below the air box. I attached the directions for removal and replacement.
Sep 22, 2021 at 8:14 AM
WISH30
  • 124 POSTS
So, as I can understand from drawings, it is near to the EGR controlling solenoid valve.
Sep 22, 2021 at 1:26 PM
MASTER ASE TECH
  • 82 POSTS
The purge valve itself is near that, it has 2 vacuum lines going to it that are about the width of a pinky finger. Also most cars have a plastic line that will have a green cap on it for the purge line. Follow this line to the purge valve.
Sep 23, 2021 at 4:41 AM
WISH30
  • 124 POSTS
And what about the canister location, is it somewhere near the fuel tank or somewhere in the front? (sorry for asking too many questions, but I must be theoretically prepared first because these 3-4 days I am not able to look directly on the car - it is on service as usual :) this time for AC leaking, this is fifth time for the same problem because here in Macedonia mechanics are so good.
Sep 23, 2021 at 9:13 AM
  • 110,246 POSTS
The evap canister is near the fuel tank. See pic 1 below. There is a canister carrier that holds it on the vehicle that will need to be removed to access the canister. See pic 2
Once the carrier is removed, you will see two vapor tubes (pic 3) and the canister vent solenoid.
Sep 23, 2021 at 10:11 AM
