Catalytic converter gets red
88,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
LINDA C. SMITH
Catalytic converter gets red, smell fuel, runs very bad no acceleration, dies when shift it to drive. Replaced IAC, EGR, MAP, plugs wires, coil and air filter. Code in van are p01684, 1282, 508, 601.
Jul 21, 2016 at 4:03 PM
HMAC300
  • 48,601 POSTS
if Catalytic converter is red then it may be a serious vacuum leak or fuel pressure problem it also can be a bad PCM. Have a local mechanic check this the 1684 just means codes have been cleared in last fifty ignition cycles, so these may have been there for quite some time.
Jul 21, 2016 at 11:56 PM
