bank 1 camshaft position sensor?
198,000 MILES
BENNY13
where is the CPS located ... i have already replaced the bank 2 CPS ... i cannot find where the CPS for bank 1
Nov 10, 2025 at 1:53 PM
BENNY13
where is the camshaft position sensor in bank 1
Nov 11, 2025 at 2:56 AM (Merged)
  • 55,684 POSTS
Each cam sensor is mounted at the front of its respective cylinder head. Please watch this video to help you see the camshaft sensor locations for both banks.
Bank 1 = Passenger side (the side with Cylinder 1)
Bank 2 = Driver side
https://youtu.be/5Bj3k6kh_P8?si=PhfvTKd25NAW7FpA&t=747
Please go over this guide and get back to us if you need any more help, make sure to clear the codes once the sensors are replaced, FYI, these engine can trigger a camshaft sensor code when the timing chain, camshaft actuator or timing chain guides or worn/broken. Also, make sure the engine oil and filter are new. If the engine rattles I would suspect timing chain/actuator issues.
Please upload a short video in your response of the problem, so I can see what's going on :)
Nov 11, 2025 at 3:06 AM
