Bank 1 and 2 O2 sensors running rich?
180,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
AKSELNABOZNEY
My car listed above has been having problems related to the engine running rich. It used to be misfiring and was fixed with multiple sets of new injectors and spark plugs. Yet the engine is still running rich and idling roughly. We have replaced almost everything to do with the fuel line and system, evap solenoids, every rubber tubing piece, new intake gasket, cleaned throttle body, new O2 heater unit sensors twice, new MAS, ran a smoke system through the engine and found no leaks, replaced PVC valves and cleaned/ inspected every inch of the engine. I am curious if it has to do with the ECU and ECM systems or any voltage issues.
Any ideas to what the issue could be related to?
Feb 20, 2025 at 9:14 AM
  • 55,588 POSTS
The idling roughly is the clue, if the engine is misfiring it will push the long trim lean which will cause the short trim to be rich. Let's do a compression test first to make sure the engine is in good shape, or we will be chasing our tails.
These guides can help:
and
https://www.2carpros.com/articles/why-an-automotive-engine-will-run-rich
Please go over these guides and get back to us.
Feb 21, 2025 at 2:37 AM
