Removing wheel knuckle from lower ball joint
181,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
DRTUCK318
  • 7 POSTS
Having difficulty removing wheel knuckle from lower ball joint.
Jan 14, 2022 at 3:34 AM
SQM
  • 6,383 POSTS
You will need a ball joint separator to get this job completed.
Keep in mind that many times the suspension components can be seized and will require extra effort to remove.
Can you tell me what you have tried so far and what exactly is the issue?
Here is a helpful guide:
https://www.2carpros.com/articles/how-to-release-a-ball-joint
I have attached the replacement procedure below for your reference.
Jan 14, 2022 at 4:11 AM
