Ball joint installation
300,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RWALLACE33
  • 25 POSTS
Hey, I pressed in my new Moog ball joints and the nipple is a bit off, where it should be? Can I press it out and back in straight? or with the hole in the control arm be to stretched out?
Dec 19, 2018 at 4:22 AM
Good afternoon,
You can press it out and back in again. no harm will be done unless you use a torch to heat it up.
Dec 19, 2018 at 5:53 AM
RWALLACE33
  • 25 POSTS
Thanks. I used a small propane torch, and ball joint press, and a hammer to press out the old ones. I Didn’t get it that hot. You think it’s still okay?
Dec 19, 2018 at 9:30 AM
Heat weakens the metal. Keep an eye on it to be sure the joint doesn't move.
Dec 19, 2018 at 9:39 AM
RWALLACE33
  • 25 POSTS
Okay. thank you for your prompt reply. So should I just draw a line then on the ball joint and control arm and just check after a couple days of driving and every once in a while?
Dec 19, 2018 at 9:52 AM
That is correct.
Dec 19, 2018 at 1:49 PM
