How to replace ball joints
230,000 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
JUSTIN JOHNS
How do you put the new ones on?
Nov 1, 2016 at 2:41 PM
CARADIODOC
  • 34,413 POSTS
This is not a do-it-yourselfer project. If you want to attempt this yourself, get a copy of the manufacturer's service manual and read through the many pages of instructions. Normally I do not recommend Haynes or Chiltons manuals because there is so much they do not cover, but check if they do cover this job.
You are going to need a ball joint press regardless if you are replacing the uppers or the lowers.
Nov 1, 2016 at 2:58 PM
