I did a timing belt replacement on this car, but it also has a balancer shaft belt. When I started the car the balancer shaft belt came off. I thought I did not tighten it enough. So, I repeated the procedures again but this time I made sure it was tight matching the pointers as required. On the crank shaft and balancer shaft sprocket. It popped out again. What could I be doing wrong?
Nov 9, 2022 at 1:17 PM
