I have a bad wire that runs from the crankshaft position sensor to the computer. Can you tell me what pins on the computer connect to the sensor?
Oct 5, 2023 at 7:37 AM
AL514
✓Experienced Mechanic
Hello, sure we can get you any diagrams you need, are you dealing with a broken wire?
Oct 5, 2023 at 8:11 AM
ENIGMA1985
MEMBER
It's either broken or there's a short. Either way, I need to know which wires I need to look at so I can follow it from the computer to the sensor.
Oct 5, 2023 at 8:19 AM
AL514
Just be aware there is a black shield wire that runs over the 2 Crank sensor wires to shield them from interference, and they are spliced into the crank sensor wires. The two main crank sensor wires are pins 62-yellow/violet and 63-green/brown.
The 1st diagram is the OEM so it should be correct on coloring.
