Bad vibration
200,126 MILES • 5.0L • V6 • 2WD • AUTOMATIC
BRANDON TERRY
Car started vibrating really bad after I changed a bad spark plug and coil. What could be the issue?
May 4, 2018 at 9:51 AM
  • 55,658 POSTS
Did you change all of the spark plugs because it sounds like you may have cracked one. If there is a check engine light that will tell us which cylinder is having the problem.
and
https://www.2carpros.com/articles/how-to-change-spark-plugs
Cheers, Ken
May 6, 2018 at 9:56 AM
BRANDON TERRY
No check engine light. It vibrates when I accelerate until the car reaches thirty to forty mph and levels out until braking and the vibration returns. I was told it could be a bad tie rod.
May 6, 2018 at 10:09 AM
  • 55,658 POSTS
Is the car vibrating or the engine? Can you shoot a quick video of the problem and upload it here in your response?
May 7, 2018 at 4:10 AM
