bad valve seals or plug tubes
2000 TOYOTA CELICA
120,000 MILES
SHICKMAN
Car has two plugs with oil on them.one has s little the number four had crud and is saturated in oil.car idles relatively ok but ad soon as yougive it gas it runs rough. codes came up showing misfires on all cylinders and a cat malfunction . also it is running rich.is this my valve seals or the plug tube seals.i think the socket used tp pyll tje plugs had some oil on it too
Jul 10, 2013 at 11:56 AM
  • 110,240 POSTS
Do you have oil on the part of the plug that goes in the engine or is the top part covered? If it is the part that goes into the engine, do you see blue smoke from the exhaust?
Jul 10, 2013 at 12:27 PM
SHICKMAN
The end that goes in the engine has oil on ait. not sure about the smoke. car hasn't been driven in a year but I'm pretty sure it has some since the number four plug is oil fouled. its been run at idle since then and revved a little just to charge the battery
Jul 10, 2013 at 8:37 PM
  • 110,240 POSTS
If the plug is oil filed, it could be rings, valve seals... Replace the plugs and see if there is blue smoke coming from the exhaust. If there is, we will need to do a compression test.
Jul 11, 2013 at 1:06 PM
SHICKMAN
ok, so I changed the valve cover gasket and plugs which solved the oil fouling of the plugs.ran the car repeatedly and checked the plugs to make sure the condition was gone.cut the cat out for replacement and disconnected the 02 sensors since they are fouled.the car is rich misfiring. when you run in there is a lot of unburned fuel. ran the car for 20 mins to try and rule out an ect issue. car was slow to warm up and cooling fan didn't come on.car was slightly under temp. but I don't think the ect would cause this condition. there is no blue smoke. even without the cat.
Jul 14, 2013 at 3:26 AM
  • 110,240 POSTS
I don't know why, but this just showed up in my mail. Sorry it has been so long. Have you had any luck with the issue?
Aug 10, 2013 at 2:26 PM
