I had a bad misfire it turned out to be the wires but I had the intake manifold off several times the misfire is cleared up. Now I have two codes I had checked P1505 and P1507. Idle speed control valve. Found it check the connection The connection is good but I was wondering if I could just take off the sensor and the control and clean it? I see if it was bumped around a bit the valve getting stuck. Any suggestions before I change it? Or if I should change it?
Feb 18, 2020 at 4:53 AM
