hey brother back again! got to quit meeting like this! Okay, I've got new cats just changed the fluid and filter on the transmission and also i had #2 spark plug under oil. so, i replaced both sides O-rings and valve cover gaskets, no leaks on the gaskets but there is a leak on the transmission gasket. no codes as of yet. its been a day about 30 miles. Do you think it could be the EGR valve making it run lean or transmission getting hot? It shifts great up/down shifting and if it were the transmission it would go into limp mode, correct? oh, yea topped of the rear pumpkin, which I'm still getting that cracking/popping sound at low speeds? Hopefully you guys can help me out quickly. My mom has a doctors appt. coming up soon, i appreciate it. can't film the smell sorry!
Jul 26, 2023 at 12:55 PM
