Bad engine miss
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
CORISSA LYNN BRADLEY
Car ran decently, a little weak, intake gasket was changed, car has had a miss ever since. It cranks and idles, but when you put it in gear it sputters and shuts off. Car can be driven by constantly patting the gas pedal.
May 4, 2018 at 4:57 AM
  • 110,246 POSTS
Hi and thank you for using 2carpros.com Since you replaced the intake gasket, I would recommend checking engine vacuum to make sure there are no leaks. If you have a bad leak, it can do what you described. Keep in mind, whoever did the work may have simply forgot to reconnect a hose or the new gasket may have failed.
Here is a video describing how to locate a vacuum leak:
https://youtu.be/xN5pcM-5bso
Here is a video describing how to determine if there is a leak:
https://youtu.be/4ktw1X4W_-k
I have attached a general vacuum diagram for your review.
I hope this helps.
May 5, 2018 at 1:16 PM
