Bad shifting
200,701 MILES • 4 CYL • AUTOMATIC
JAEFARLEY
Hard first rpm to second rpm shift, but after it catches the second rpm it runs great. Also the check engine light is on.
Aug 13, 2019 at 9:27 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Having the check engine light on means there is a trouble code stored in your cars computer.Since you say it shifts hard it could be a transmission trouble code.If you don't have access to a scanner/code reader most auto parts stores will check for free (AutoZone). Here is a tutorial showing what is involved:
Once you have the code(s) read get back to us with the information to help properly diagnose the problem.Hope this helps and thanks for using 2CarPros.
Danny-
Aug 13, 2019 at 9:37 AM
