Bad performance of engine
255,346 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
UWEM EKPO
My engine does not rev above 3000 rpm's.
Oct 10, 2017 at 3:45 AM
  • 31,937 POSTS
Start with a full tune and code read. check fuel pressures and compression, check and adjust valve clearances as well. check for arcing inside the distributor cap and that the carbon brush is not burnt out. also, check rotor air gap. re-post for further assistance if required.
Oct 10, 2017 at 8:13 AM
RENEE L
  • 1,260 POSTS
Hi UWEM EKPO,
I am sending you a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Oct 11, 2017 at 5:03 AM
