Bad mpg, cannot find the cause
60,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
WALLY AB
  • 97 POSTS
I bought this car used a few months ago. Warranty is almost up. I took good care of the car, and previous owner car maintenance records. I checked the spark plugs as well, the gap was the same 0.040". I am still getting poor fuel economy. Usually around 17-25 mpg, and 35-30 mpg at best on the highway.
Aug 3, 2018 at 12:29 PM
  • 55,673 POSTS
At 60,000 the park plugs need to be replaced regardless of wear also the throttle actuator needs to be cleaned. Use OEM parts.
https://www.2carpros.com/articles/how-to-change-spark-plugs
and disconnected the battery first.
Cheers, Ken
Aug 5, 2018 at 11:39 AM
WALLY AB
  • 97 POSTS
I cleaned the throttle body today but no real improvement in mpg.
Aug 9, 2018 at 7:17 AM
  • 55,673 POSTS
Did you do the spark plugs please use OEM plugs? Also, lets run the codes to see if anything comes up. It could be a amp sensor that is a little off.
Cheers, Ken
Aug 10, 2018 at 3:51 AM
WALLY AB
  • 97 POSTS
So I checked everything. I ordered the OEM NGK laser iridium plugs from Korea, and just installed them today. I did not want to risk getting counterfeits from China. The dealers sells them locally at $20.00, parts store around $16.00 each, and I got all four for like $30.00.
Aug 23, 2018 at 5:41 AM
  • 55,673 POSTS
Nice work can you service the throttle body as well? Here is a guide:
Cheers, Ken
Aug 23, 2018 at 1:09 PM
