bad mecury
1992 MERCURY MARQUIS
139,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
PUTZ-2015
the starter and soilanoid have been replaced . everthing works good for a while. then the only way to start it is jump the soilnoid . when turn key ther is no sound
Apr 14, 2016 at 9:37 PM
HMAC300
  • 48,601 POSTS
check items in pic then check to see if ignition switch is sending power through the neutral switch
Apr 14, 2016 at 11:49 PM
  • 55,421 POSTS
This is from PUTZ-2015 who sent it through our contact system for some reason - "the solved the problem needs a ignition switch. thanks could you tell me where the headlight ground is on 2003 dodge caravan se Canadian model" The headlight ground is near the headlight housing down on the radiator core support, follow the wiring harness downward to locate
Apr 19, 2016 at 12:03 AM
