Bad knock sensor module?
98,500 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
VANNAK
Noise when the engine starts and no sound after, during drive. When on the stop sign and start up speed I got noise soon and lose.
This is a bad knock sensor module or?
Sep 6, 2023 at 9:46 PM
  • 110,246 POSTS
The knock sensor is designed to adjust ignition timing (fine-tune) under different conditions. When there is an issue, the sound is usually described as a valve ping. Is that what you are experiencing? Is the check engine light on and a stored code present related to the sensor?
Let me know. Also, here is a link you may find of interest:
https://www.2carpros.com/articles/how-a-knock-sensor-works
Also, if it is loud enough for you to record, please do so and upload it for me to hear.
Sep 7, 2023 at 7:12 AM
