Bad idle, exhaust smell, car shakes and empty coolant
2008 VAUXHALL VECTRA
42,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
FIETCH2002
Recently my car has been having a rough idle, it has been shaking because of this. When revved up a little the exhaust starts to smell like gunpowder. I have owned the car since new and always changed the oil. The coolant reservoir did have some gunk in it, as well as the breather pipe and breather filter. Cleaning them out and topping it up did nothing and there is not any engine light or codes coming up.
I also cleaned out the throttle body and it did not do anything.
Mar 31, 2018 at 3:52 AM
  • 55,423 POSTS
This sounds like you have a blown head gasket which will cause all the problems you have described. Here is a guide to help us confirm the failure:
Cheers, Ken
Apr 2, 2018 at 4:06 AM
FIETCH2002
Thanks Ken, I am on holiday at the moment, but I will let you know about the car when I get back.
Apr 3, 2018 at 12:15 AM
  • 55,423 POSTS
Okay sounds good. :)
Apr 3, 2018 at 3:56 AM
FIETCH2002
Ken - it was the belt tensioner that was bad, I took the car to a garage and they found the source of the noise and fixed it.
Apr 4, 2018 at 8:02 PM
  • 55,423 POSTS
How can the belt tensioner cause the car to loose coolant and idle bad? Glad you got it fixed though. How much did they charge you if I can ask?
Apr 5, 2018 at 4:11 AM
