Does not idle, shuts off while driving when I let of the accelerator pedal?
73,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
GATOR2023!
My 318 when running down the road, I will let off the gas and the engine will lope and shut off. How can I correct this?
Jun 21, 2023 at 1:04 AM
  • 55,732 POSTS
This can be a vacuum leak, a bad IAC valve or the EGR valve sticking open. Please go over this guide which should help us fix it:
https://www.2carpros.com/articles/stall-at-idle
Here is the vacuum leak guide, use only when the engine is cold:
Here is the location of the IAC and EGR valve so you can change it out. here is a video that can help you test the EGR:
https://youtu.be/DqUCbbKdWf4
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 21, 2023 at 5:43 AM
