Bad grinding noise in 4wd?
201,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
AIDEN MCLEAN
It snowed real good last night so when I went to take the vehicle listed above to work this morning it made a horrible noise pulling out of the driveway. Thinking it was my driveshaft I got out and wiggled it and it feels fine. So, I’m led to believe it’s my transfer case or differential. I did the differential fluid about a week or two ago and it looked fine, no metal in the oil or uneven wear. All tires are the same size so I’m not sure what could’ve caused it.
Jan 4, 2024 at 5:08 AM
  • 110,248 POSTS
When you serviced the differential, was the new fluid filled to the bottom of the fill hole? Also, have you checked the transfer case fluid to make sure it isn't low?
How would you best describe the noise? On these vehicles, at the front of the front drive shaft, there is a CV-type joint that connects the driveshaft to the front differential. If it is faulty, it will make a ton of noise. Check that for evidence of leaks and make sure there isn't excessive play in it.
I found a few pics online showing the driveshaft.
Let me know what you find. Also, when you check for play, have it in 2wd to prevent pressure on it.
Take care and let me know if I can help.
See pics below Pic 1 is from my manual. Pic 2 is a rebuild kit for the joint. I've done several. It's a little time-consuming, but not a difficult job. Pic 3 is the entire shaft.
Jan 4, 2024 at 10:16 AM
AIDEN MCLEAN
I went to take off the drive shaft last night after work, seeing how everything else worked and that was the only 100% new part I swapped into it and I noticed one of the pins/clips that hold the u-joint caps in was missing and one of my caps was out pretty far and it was making an aggressive clunk noise because of that.
Jan 5, 2024 at 12:16 AM
AIDEN MCLEAN
Also, my Jeep doesn’t have that shaft anymore I upgraded to a traditional double carden, nothing but I would not like for those requazzas on my end, lol.
Jan 5, 2024 at 12:17 AM
  • 110,248 POSTS
Has the issue been resolved? It sounds like you found the issue.
Jan 5, 2024 at 3:09 PM
