Bad fuel pump after oil change?
107,000 MILES • 6 CYL • AUTOMATIC
CDEHRHART
Today, I took my 2005 Jeep Liberty Limited 6 cylinder in for an oil change and tire rotation at a local Pep Boys. They also did an AC check as it was blowing warm. After picking up the vehicle and driving it for a moment, the car was shaking when I got to a nearby stop light (about 30 seconds away), and it then shut off and would not restart. A group of military guys were kind enough to help push it back to the shop.
Pep Boys looked it over and determined there was very little fuel pressure and advised they could fix it in a few hours for about $1100. Needless to say, I had it towed back home for free thanks to my insurance. This brings my ultimate questions....
1. Will a fuel pump just go bad suddenly, with no warning? The Jeep ran perfectly with no starting issues at all.
2. Is it possible in the maintenance I described to cause this issue?
I have checked thrice over all the hoses and show nothing loose...oil level is fine. Any help and advice is appreciated
Jul 5, 2014 at 8:42 AM
HMAC300
  • 48,601 POSTS
ya they can do that. I f you have a large rubber hammer bang the bottom of the fuel tank andsee if it starts if it does then it would tell you . hard telling how long it would work however. you can also use the palm of your hand may work as well.
Jul 5, 2014 at 10:19 AM
