Bad fan clutch
123,500 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
EWCEP
My vehicle runs real hot in traffic and the A/C won’t cool until the car moves. I can stop the fan easily with a glove on and hold it still with little or no resistance. How can I be sure it’s bad? I checked the fuse and relay.
May 25, 2019 at 3:16 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Are you referring to an electric or mechanical style fan on your vehicle? Thanks for using 2CarPros.
Danny-
May 25, 2019 at 10:49 PM
EWCEP
Hi Danny, my vehicle listed above has an electronic fan clutch and I can stop the fan easily with my hand. I don't think it is moving much air. how can I be sure if its good or bad?I think i need to replace it but not 100% sure it is bad. Thanks, Craig
May 30, 2019 at 2:24 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, sounds like the electronic fan clutch is faulty. I've attached three pictures below as a step-by-step on how to remove and replace.Hope this helps and thanks again for using 2CarPros.
Danny-
May 30, 2019 at 11:41 PM
