Possible bad engine mounts
135,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JGONZO2398
  • 375 POSTS
I have been noticing that when I sometimes brake hard the car will clunk sometimes as if something is knocking against the frame or the front end of the car when I stop, as if something moved forward. Did some research online and did this test on my car where I hit the brakes and the gas at the same and as you can see in the attached video, the engine moves quite a bit. I remember replacing all of the mounts last year, and I replaced the T-bone looking mount on top of the engine as well. What do you all think?
Apr 16, 2019 at 10:41 AM
Good evening,
From your video, that is normal wear for the mounts.
Where does the noise sound like it is coming from?
I would have the lower control arm bushings, struts, and frame mounts.
https://www.2carpros.com/articles/popping-noise
Apr 16, 2019 at 11:12 AM
JGONZO2398
  • 375 POSTS
I had all four shocks/struts along with the strut mounts and brand new control arms with new bushings installed early last year. would it be that?
Apr 16, 2019 at 11:20 AM
It is possible, but I would have them checked anyway.
Also, have them check the sub-frame mounts for wear or being loose.
Apr 16, 2019 at 11:26 AM
JGONZO2398
  • 375 POSTS
Hi, another thing I forgot to mention was that my car clunked whenever I switch from park to reverse, reverse to drive, and vice versa. Last weekend I had all three mounts replaced (the two engine mounts and transmission mount), I still have that clunk noise whenever I shift gears. Any guesses?
May 9, 2019 at 12:40 AM
Did they make sure the engine idle speed is adjusted correctly?
May 9, 2019 at 12:52 AM
JGONZO2398
  • 375 POSTS
I do not even know what that is, haha.
May 9, 2019 at 12:55 AM
If the engine is running too fast, it will do this. See if they can check and see if the idle speed is correct.
May 9, 2019 at 2:12 AM
