Crank no start
185,623 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TRISTON C. G. THACKER
  • 8 POSTS
Engine will turn but will not crank. I was thinking it might have jumped time or the timing chain might have broken. It does not make any bad noises when I try to crank it. Essentially the engine will turn forever. I have spark and gas. I figured it might be the CPS.
Feb 21, 2018 at 2:43 PM
Good morning.
If you have spark and fuel, the rank sensor is working.
I would start by checking the compression. That will tell if you have a timing chain failure.
Feb 21, 2018 at 5:37 PM
RENEE L
  • 1,260 POSTS
Hello TRISTON C. G. THACKER,
Here is a link to an article form this site that features written step by step instructions, pictures and a video explaining how to conduct a compression test:
If you need further instructions or have another question please come back to the site, we are here to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Feb 22, 2018 at 3:47 AM
