Bad computer
2008 FORD F-550
58,000 MILES • 6.4L • V8 • TURBO • 4WD • AUTOMATIC
JIMMYFROMTRUCK
  • 25 POSTS
So this is a 6.4 powerstroke. It has low mileage and has many problems. The truck loses throttle control and you have to turn off and turn back on. The truck will smoke a lot and then will not smoke at times. Sometimes exhaust comes through engine bay into cab most of the time, other times it will not. It will run really bad, sounds like a 6.0 and lopes and shakes truck, and then it will run great. When you turn the truck on, some things on interior will not get power. This sounds like bad computers to me. What could it be? I do not have the truck readily available or tools to experiment.
Dec 30, 2017 at 10:43 AM
Good morning
Do you have the codes the are set? If you do not then a parts store will read them for free.
Dec 30, 2017 at 8:34 PM
JIMMYFROMTRUCK
  • 25 POSTS
I do not have the codes written down, but the mechanic said there were a lot. The screen on the dash was a wrench and then will say trailer brake controller fault. Could the computer be fried?
Dec 31, 2017 at 3:50 AM
that would be an expensive guess. In most cases, it is not.
We need the codes to help narrow the area of failure. See if you can get them read again.
Dec 31, 2017 at 4:06 AM
JIMMYFROMTRUCK
  • 25 POSTS
I will and I will post them here when I have them.
Dec 31, 2017 at 4:11 AM
Sounds like a plan.
Dec 31, 2017 at 4:19 AM
