Brake pedal goes down to the floor before stopping the vehicle
78,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
PAT ELIMINATOR 70
Replaced master cylinder, proportion valve, front calipers, rear wheel cylinders and bled brakes (several times). I have checked the brake lines for leakage.
Jun 16, 2019 at 9:39 AM
SCGRANTURISMO
  • 4,897 POSTS
You either have air in the brake lines or a leak that is allowing the brake fluid pressure to bleed off. I have included a link below for you to go to:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jun 16, 2019 at 9:51 AM
