Front passenger brake caliper locks up
97,270 MILES • 3.6L • 6 CYL • AUTOMATIC
RCALLENS1
Front passenger side caliper was locked up, I’ve replaced the caliper with a new one. I’m having the same problem, took the car to a mechanic they say master cylinder or brake booster, tried that still the same problem. so they put my original master cylinder and boost back on and just charged me a deductible which $100.00 but the cleared me for 50. yet I still have the same brake locking up problem, I’m tying to think of what to do, I need directions. I’m being told about the ABS system or so, but there is no ABS warning light on at all.
Dec 2, 2020 at 10:39 PM
I suspect you have a rubber brake line that is failed. So what happens is when you apply the brakes, and the brake fluid pushes the caliper piston out the rubber line does not allow the fluid to return so the caliper sticks and then overheats. So if you have replaced all this and no change, I would replace the line and go from there.
Then I would flush the entire brake system because these fail one of two ways. Either age/wear or contamination. So if you have not flushed the fluid out, here is a guide that will help with that:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Dec 3, 2020 at 1:55 AM
RCALLENS1
Okay, I’ll try that first. do you think it’s an ABS system problem without the light being on?
Dec 3, 2020 at 2:11 AM
Good afternoon,
Calipers can lock up from either the caliper itself or a failed brake rubber brake line.
https://www.2carpros.com/articles/brake-caliper-replacement
https://www.2carpros.com/articles/car-pulls-right-or-left-when-driving-or-braking
The easiest way to tell is to pump up the brake pedal and when the caliper does not release, open the bleeder screw. If fluid comes out and the wheel frees up, it is the brake hose that is the issue.
I attached the procedure for changing the hose. It is the same for both sides.
Front Brake Hose Replacement (J64)
Removal Procedure
Warning: Refer to Brake Dust Warning See: Brakes and Traction Control > Technician Safety Information > Brake Dust Warning.
Warning: Refer to Brake Fluid Irritant Warning See: Brakes and Traction Control > Technician Safety Information > Brake Fluid Irritant Warning.
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle See: Vehicle Lifting > Procedures > Lifting and Jacking the Vehicle.
2. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation See: Wheels and Tires > Removal and Replacement > Tire and Wheel Removal and Installation.
3. Disconnect the brake pipe fitting (1) from the brake hose.
4. Cap the brake pipe fitting to prevent brake fluid loss and contamination.
5. Remove the brake hose retaining clip (1).
6. Remove the front strut assembly pinch bolt (1) from the steering knuckle and brake hose bracket.
7. Remove the brake hose fitting bolt (1).
Note: Do not reuse the brake hose fitting gaskets.
8. Remove and discard the brake hose fitting gaskets (2) from the brake hose fitting (3).
9. Remove the brake hose.
Dec 3, 2020 at 6:07 AM
