Bad brakes
1,256,889 MILES • AUTOMATIC
SARAHLIZ
  • 9 POSTS
Hi. My car takes a lot of time to stop when I hit the brakes. I have to brake early if I have to stop at traffic light for example. But I really like it when the brake pedal feels soft because I don't like a brake pedal which is hard to press.
Jan 25, 2019 at 1:00 AM
Good afternoon
Brake pedals need hard pressure to stop the stop the car. Soft pedals indicate an issue with the fluid system. It could be air or a fluid leak.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
You need to have the system checked as it could be a fluid leak or a bad master cylinder.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Jan 25, 2019 at 1:36 AM
SARAHLIZ
  • 9 POSTS
Its a fluid leak
Jan 25, 2019 at 2:01 AM
OK, Thats needs to be identified and repaired. Then the system needs to be bled to get the pedal back to where it is safe.
Jan 25, 2019 at 2:12 AM
SARAHLIZ
  • 9 POSTS
Yesterday I was driving..and the brake pedal was like this.
Jan 25, 2019 at 11:38 AM
OK, first, nice shoes.
You are pressing on the gas pedal in that picture? Why?
Jan 27, 2019 at 1:21 AM
SARAHLIZ
  • 9 POSTS
Cranking problem and then brake problem
Jan 27, 2019 at 7:53 PM
Cranking problem?
Can you explain?
The low pedal has no effect on the starting.
Jan 27, 2019 at 7:55 PM
SARAHLIZ
  • 9 POSTS
First I was cranking...and was driving to go to the shop
Jan 27, 2019 at 8:32 PM
Dies it start. Please give me as much information as you can.
Jan 27, 2019 at 8:36 PM
SARAHLIZ
  • 9 POSTS
Car cranks when starting.Take 5 minutes to start the car..then I drive to the shop with faulty brakes
Jan 28, 2019 at 12:53 AM
Can you check the fuel pressure?
Jan 28, 2019 at 4:41 AM
SARAHLIZ
  • 9 POSTS
Fuel pressure is good.
Jan 29, 2019 at 12:06 AM
What is the exact number for the fuel pressure? Good does not tell me anything.
Jan 29, 2019 at 12:30 AM
SARAHLIZ
  • 9 POSTS
Between 40 and 50.
Jan 29, 2019 at 12:32 AM
Is this the fuel injected motor?
The spec is 52-55
The pressure is too low. Sounds like you need a fuel pump.
Jan 29, 2019 at 1:25 AM
SARAHLIZ
  • 9 POSTS
And what about the brakes?
Jan 29, 2019 at 3:47 AM
You said it was a fluid leak. You need to get it checked at a shop to determine the location and have repairs made so you have safe brakes.
Jan 29, 2019 at 6:16 AM
