Okay, I am going try and keep this short, so if you want more details just ask.
Recently installed a new stereo system (loud subwoofers) after install normal idle voltage has been 14-14.3 (quality aftermarket voltmeter). With stereo at full tilt and engine idling I'd get voltage drop to 13.4 at worst and recover to 14+ immediately.
Few days later now my idle/driving volts read 13.1 with stereo off.
(Edit: had bad voltage drop (down to eleven volts at times) for a couple weeks with stereo full tilt until I had amp set professionally, added second battery day before that was done. Then few days later the above started)
Upgrades I have done:
One year old stock lead acid battery up front.
200 amp alternator.
Big three in 1/0 wire
Secondary larger AGM battery in trunk, 1/0 wire from front battery. 1/0 ground in back also.
(About one year old out of my truck)
SMD VM-1 volt meter. (Reads very accuratly)
What I am assuming is happening now is that the lead acid battery has a bad cell even though it is only one year old. Yes, it is a cheapo wally world battery. But should not happen that quick. But I guess with the abuse this stereo does to them okay.
Question is, can someone confirm my thoughts or is there possibly another issue going on as well?
200 amp alternator.
Mar 28, 2018 at 9:56 AM
