Backfiring and sputtering
180,000 MILES • 4WD • AUTOMATIC
TAMEE SUMMERS
When I go to take off it sputters really bad and doesn't have very much power if I push on the gas then it takes off and it'll backfire but once I'm going fast it's okay it's just whenever I go to slow down it'll start sputtering and backfiring
Jun 12, 2021 at 5:30 AM
JOECALL
  • 6 POSTS
Hi Tamee,
It sounds like you have a misfire related to worn out ignition parts. In this case it sounds like at least one but likely several failed coil packs. If you have a way to check codes I would not be surprised if you have codes in the p0300-p0308 range (Many auto part stores can read codes for you if you do not have the tool).
Here is a guide that will help with more info on this:
If you have a P0301 then that points to the cylinder 1 coil pack. If you have a p0302 then the cylinder number 2 coil pack and so on. I have included some images that show the cylinder numbers and coil pack locations. Please give this a shot and let me know what happens.
here is a link that has some tune up basics which include a video of the coil pack removal on another type of car, but it is basically the same:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Thanks,
Jun 20, 2021 at 9:52 PM
