Backfires through air manifold
165,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
RICHARD LODGE
Hard starting backfires a lot slow to respond to throttle low power, very hot exhaust manifold, have cleaned EGR and injectors. Replaced TPS, ICU cam sensor, MAF sensor, new timing belt marks on point and new plugs. I had injectors out to clean tested on fuel rail all pulsing at same time, new fuel pump.
Oct 1, 2018 at 9:53 AM
  • 110,248 POSTS
Confirm that the catalytic converter is not plugged. Also, a rich fuel mixture can cause this, so I recommend checking the fuel pressure to make sure the regulator is working. Here are links that shows how it is done. Also, I attached a link that discusses different causes for a backfire.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/engine-backfires-while-running
Do these checks and let me know what you find.
Oct 2, 2018 at 11:53 AM
