backfires
500 MILES • 3.7L • 6 CYL • 2WD • MANUAL
NORMAN OGDEN
will run good after everything gone threw ,then will start not accelerating properly then backfires under load ,after warmed up ,seems to become ,flooded as plugs have oil threads appearance and light un-burned look on spark area ,
i have not checked fuel pressure or coil ,
Mar 19, 2017 at 6:46 AM
  • 55,676 POSTS
Hello Norman,
It sounds like the condenser is going bad, I would start with a new set of points and then install a new condenser and go from there.
Best, Ken
Mar 22, 2017 at 9:45 AM
