Backfires I just changed the plugs?
5.7L • 4WD • AUTOMATIC • ELECTRIC
JIMENEZDAVID8083
When under life it backfires I just changed the plugs and wires that’s the right way to set the wiers
Nov 20, 2026 at 6:57 PM
  • 55,758 POSTS
So it sounds like you have the spark plug wires on incorrectly? Did you have this problem before you began the work? Here is the firing order so you can recheck you work. Can you please upload a short video of the way the engine is running so I can see it?
Nov 21, 2026 at 10:11 AM
