Good morning,
Backfires are the result of spark occurring when it should not be.
https://www.2carpros.com/articles/engine-backfires-while-running
Some possibilities
1. Cracked distributor cap or bad rotor.
2. Ignition wires shorting out.
3. Retarded ignition timing from bad timing chain.
4. Lean fuel mixture from low fuel pressure or clogged injectors.
Jan 3, 2019 at 9:04 PM
