Backfires
120,000 MILES • 2.9L • V6 • 4WD • MANUAL
LYNN RAULSTON
When you first start it and give it throttle it wants to backfires.
Jan 3, 2019 at 8:45 PM
Good morning,
Backfires are the result of spark occurring when it should not be.
https://www.2carpros.com/articles/engine-backfires-while-running
Some possibilities
1. Cracked distributor cap or bad rotor.
2. Ignition wires shorting out.
3. Retarded ignition timing from bad timing chain.
4. Lean fuel mixture from low fuel pressure or clogged injectors.
Jan 3, 2019 at 9:04 PM
