Backfire/transmission not shifting properly
200,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
TERRY.MULLEN
Drives fine. Shifts from first to second then when you would expect it to shift to third it starts to backfire and miss. Back off the throttle a bit and it will shift to third and then it is fine.
Jun 10, 2018 at 10:02 AM
  • 55,743 POSTS
This is a classic misfire problem. I would do a full tune up with plug wires. Use all OEM spark plugs and wires. Here is a guide to help you:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Cheers, Ken
Jun 12, 2018 at 3:42 AM
