Will not start after engine shut off do to no engine oil
485,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BASSAM AL MALIK
I was driving the car when it start to lose power tried to park in the road side, the low pressure oil light came out then the car was off by itself. Checked the engine no oil. No leaks when I refill the engine with oil. Try to start the car but it would not start, it cranks but sound of backfire come from exhaust. Cleaned the sparks. No benefit.
Dec 16, 2020 at 9:05 PM
  • 110,248 POSTS
Often times a backfire is an indication of excessive fuel entering the engine. Do me a favor, take a look through this link, and check the things it mentions:
https://www.2carpros.com/articles/engine-backfires-while-running
If possible, record what it is doing, upload it, and then I'll be able to hear and see what is happening.
Let me know if the link helps or if you have other questions.
Dec 17, 2020 at 12:53 PM
BASSAM AL MALIK
Thank you for your kind respond, I already did most of what is in you link. Attached video for your kind reference.
Dec 17, 2020 at 3:19 PM
  • 110,248 POSTS
Okay, after listening to the video, we need to check fuel pressure. It sounds like it may be low or the pump has failed. Here is a link that explains in general how to check pressure:
Here are the manufacturer's specifications:
2005 Lincoln Truck Navigator 4WD V8-5.4L SOHC VIN 5
Pressure, Vacuum and Temperature
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Specifications Pressure, Vacuum and Temperature
PRESSURE, VACUUM AND TEMPERATURE
ITEM .................... SPECIFICATION
Fuel Pressure
Key on, engine off .................... 240-310 kPa (35-45 psi)
Engine running .................... 193-310 kPa (28-45 psi)
___________________________
Let me know what you find.
Dec 18, 2020 at 3:16 PM
BASSAM AL MALIK
Thanks. I did the checked and clean the sparks and coils. I put a new fuel trail pressure sensor. I used light tester to check the voltage of the fuel injectors its ok but when I checked the fuel trail sensor cable the light was not as bright as when I checked the injectors cables. I connected the fuel pump directly from the fuse box. No change. The car did not start and still acting the same.
Dec 20, 2020 at 11:52 PM
  • 110,248 POSTS
Have you confirmed if the fuel pump is producing pressure? If so, how much pressure was indicated on the fuel pressure gauge?
Dec 21, 2020 at 11:53 AM
