Truck is backfiring when trying to accelerate
284,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
PADENFD
Idles fine. Drives fine, but when you get on the gas demanding power from the motor it bogs down and backfires. Things that have been changed; temperature control sensor, whole TBI rebuild , timing has been checked and is right on. Fuel filter changed, spark plugs , wires, cap and rotor , map sensor, cleaned EGR.
Nov 23, 2019 at 3:55 AM
  • 110,251 POSTS
Is it backfiring through the exhaust or intake? Take a look through this link and let me know if it helps. Also, let me know from where it backfires.
https://www.2carpros.com/articles/engine-backfires-while-running
Nov 23, 2019 at 9:52 AM
PADENFD
Hi Joe,
The backfire to this truck is through the intake and up in the TBI. By your videos I have been watching I am thinking the fuel pump is not doing right. So I’m just going to replace it. Will see what happens. I’ll let you know.
Nov 23, 2019 at 11:46 PM
